maghaliqhna Posted January 29, 2012 Report Share Posted January 29, 2012 (edited) We all know that the wall lamps for accent lighting, such as lighting, pictures or other decorative element used on the wall. But its usefulness is more than just lighting. Wall can be used effectively for the good lighting, such as restaurants and bedrooms, and even he could fill any place or lamp light in a positive way, although the wall lamp does not respond when s 'acts of him lighting the scene is. In such an embodiment, the lamp wall, not only reduces the amount of light required to light work, but also a more homogeneous distribution of light so blinding and eye strain caused to the occupants of the room. Begin, we start with the dining room. Wall can play an important role in improving the lighting and ambience of the dining room. In most dining rooms, lighting fixtures, like chandeliers or pendant that Now shines the table is correct, the same could also create unwanted shadows on other parts of the room. Install sconces on the sides might lack of light in these areas to compensate and cancel unwanted shadows created by the lights the ceiling. If the lights Double wall may prove to be an illumination to your curio cabinet or other decorative shapes on the wall so it will only enhance the overall atmosphere and ambience of the dining room and mood of the guests. In the living room and apply the same use as wall lighting in the dining room. It could cancel unwanted shadows, but also sheds light on your wall mount precious photos and other decorative elements attached to the wall. To the right lighting, wall scones at least 6 meters above the ground and must be placed in the ideal case, the halogen lamps. Finally, in the corridors, areas traditionally poorly lit in most homes, wall sconces could provide a much needed low-light conditions. For maximum user-friendliness, it is recommended to be here for wall lamps and lighting used for decorative purposes, as in the living room or dining room, such as lighting, a small mural on both sides. For example, wall lamps for ambient lighting in the room are also used. Applications are available on the market in dozens of styles and shapes, and prices are available. . Edited January 29, 2012 by tomturd Link to comment Share on other sites More sharing options...
george_seamons Posted January 29, 2012 Report Share Posted January 29, 2012 No thanks... Link to comment Share on other sites More sharing options...
