dannytrialskid Posted January 27, 2012 Report Share Posted January 27, 2012 My bashring is set up for a right footer and haven't changed it since I got it. This is why I think that my chain snapped, because I landed on the chain too many times. Do I have to take freewheel off to change it? And, how is set for a left footer? Quote Link to comment Share on other sites More sharing options...
davidbarr Posted January 28, 2012 Report Share Posted January 28, 2012 My bashring is set up for a right footer and haven't changed it since I got it. This is why I think that my chain snapped, because I landed on the chain too many times. Do I have to take freewheel off to change it? And, how is set for a left footer? I'm assuming it's a halfring then? Something like the Trialtech halfring? If so, you'll need to loosen off your freewheel and turn the bashring the opposite direction. Hope that helps. Quote Link to comment Share on other sites More sharing options...
dannytrialskid Posted January 28, 2012 Author Report Share Posted January 28, 2012 I'm assuming it's a halfring then? Something like the Trialtech halfring? If so, you'll need to loosen off your freewheel and turn the bashring the opposite direction. Hope that helps. This one - http://www.tartybikes.co.uk/bash_rings/trialtech_alloy_twin_bashring/c1p10420.html My friend said it is set up for a right footer? Quote Link to comment Share on other sites More sharing options...
AndrewEH1 Posted January 28, 2012 Report Share Posted January 28, 2012 (edited) Twin bash rings, if fitted correctly, are suitable for both left and right footers without the need for adjustment as a 'tab' will always bash before the FFW no matter what foot is forward at the time. Half bash rings do need to be adjusted whether you are left or right footed as there is only one 'tab' to protect the FFW. Edited January 28, 2012 by AndrewEH1 1 Quote Link to comment Share on other sites More sharing options...
dannytrialskid Posted January 28, 2012 Author Report Share Posted January 28, 2012 Twin bash rings, if fitted correctly, are suitable for both left and right footer without the need for adjustment as a 'tab' will always bash before the FFW no matter what foot is forward at the time. Half bash rings do need to be adjusted whether you are left or right footer. Oh ok, I'll have to have a look next time I'm out. Quote Link to comment Share on other sites More sharing options...
MiuSliS Posted January 28, 2012 Report Share Posted January 28, 2012 I'm left footed, i use the same bash ring and i have no problems. Fitted like this. Quote Link to comment Share on other sites More sharing options...
