Azarathal Posted January 24, 2012 Report Share Posted January 24, 2012 (edited) New queation! Think I'm getting a rear king now, I'm wondering which 18t front screw on sprocket would be best to use in the place of my free wheel? And which spacer kit / rear cog would you recommend? Heya guys, with tarty close I thought I'd post here instead to help shead some light on this... Basically I absolutely love ProII rear hubs, they feel crisp, they're reliable and they sound amazing, after ripping the disc mount off of my front Echo TR hub I'm after a pair of matching ProII's and obviously going to be getting rid of my SL Freewheel. Now I've come to a problem, on the Tarty website it states "recommended 18-14 ratio with front freewheel only", I'm wondering why it's restricted to FFW? Cheers, Mikey. Edited February 1, 2012 by Azarathal Quote Link to comment Share on other sites More sharing options...
Ali C Posted January 24, 2012 Report Share Posted January 24, 2012 Sprocket clearance. Freewheel teeth are further outboard (in that they're in the centre of the 'sprocket'), whereas almost all screw-on sprockets with a base worth using are offset inboard. As a result, they hit the BB yoke. I know of people running 16:14 (on the Pure frame - you could do 16:13 on the 24 I guess?) with a fixed sprocket setup, but 18t doesn't work. All the new Echo 24" frames being 116mm spaced probably won't help, unless you've got the frame already? Quote Link to comment Share on other sites More sharing options...
Adam-Griffin Posted January 24, 2012 Report Share Posted January 24, 2012 (edited) I have a feeling it's something to do with the sprocket catching on the the frame. I guess you could possibly get away with a front sprocket smaller than 18t, but I wouldn't bank on it. How much space have you got at the minute with the freewheel? Edit: too late... Edited January 24, 2012 by Adam-Griffin Quote Link to comment Share on other sites More sharing options...
Azarathal Posted January 24, 2012 Author Report Share Posted January 24, 2012 Without looking I'd say I've got a bit of space, does it look like it'll be too much of a pain in the arse and I should just leave it? Quote Link to comment Share on other sites More sharing options...
N.Wood Posted January 24, 2012 Report Share Posted January 24, 2012 Just keep everything as it is and buy a different front hub? Sounds like you're causing yourself alot of superfluous grief for nothing to me. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted January 24, 2012 Author Report Share Posted January 24, 2012 (edited) Getting a new front hub anyway, I just like rear ProII's Edited January 24, 2012 by Azarathal Quote Link to comment Share on other sites More sharing options...
ezgonzo Posted January 24, 2012 Report Share Posted January 24, 2012 you'll be able to run an 18t tt sprocket on the front just fine and still have a few mm's to spare, the only downside you may have is ratio choice but you should be fine running 18-14 and possible 18-13, Quote Link to comment Share on other sites More sharing options...
Azarathal Posted February 1, 2012 Author Report Share Posted February 1, 2012 New question! For reference I have the 135mm echo24 trial and have about 4-5mm freewheel clearance atm Quote Link to comment Share on other sites More sharing options...
