Chain Tension On Zhi Frame
tdubz
Got my first horizontal dropout frame
before i describe my issue here is my current setup:
hope pro 2 hub
kmc chain
zhi frame
the issue i have got is that i cannot get snail cams to fit on the inside of the frame, and there doesnt appear to have any holes on the outside to run them
with my wheel slammed to the front of the dropouts i am between links to acheive what looks to be suitable chain tension
in my opinion i have three options
1. buy a shadow half link chain, but are these chains strong enough for trials, one of my biggest fears is chain snap on a drop scenario
2. buy a half link and fit it into my current chain, but i have heard these are not mega strong either
3. new hub, really dont want to do this due to cost and also like my hope hub
4. run chain tugs
if anybody can recommend either the suggestions above or any other ways to do this i would be most helpful.
how about trying a different ratio, most/all frames with horizontal dropouts have a recommended ratio, i remember having to try different ratio's with my old zhi inorder to get a nice gearing and still be able to fit the chain + get the rim somewhat central to the brake mounts,
i would stay clear of half link chains/links, your teeth will thank you for it,
you should also be able to get away without useing cam's if your running a pro 2, i'm pretty sure they've got serrated axle ends and bolts so your wheel should'nt move under load,
There isn't a bolt hole for snail cams.
Unless the hole doesn't go all the way through... in which case, you could just drill it all the way through and retap it, then you can use cams on the outside?
OR, get that single extra halflink in there and don't be a fag and keep an eye on it and it'll be fine.
hope pro 2 hub
kmc chain
zhi frame
4. run chain tugs
The Zhi frame is 135 as is your hub you should have no problem getting snail cams into the frame, if you have to pull the rear end of the frame slightly apart to get the wheel in then I would recomend you try this before any of your other options, also what gear ratio are you using on the pro 2 hub? The new frame is designed for 18:15 NOT 18:16 as said on other reply's to this topic....
Hard to explain but as the drop-out is designed to save weight. where the bolt is placed it has to only screw half way into the frame as you would hit the CNC flange zhi have made to increase weld area/save weight on the drop out, also due to this flange you could not run outer cam's.
I think your wrong, adding 3mm snail cams to each side of a 135mm hub means you'd need a dropout 141mm wide to accommodate everything nicely. Any 135mm hubs that are designed to be run with snail cams are effectively 129mm hubs with a 3mm snail cam placed either side.
I'd rather try every other option possible before I resorted to forcing the rear end of my frame apart - resulting in a lot of un-needed stress to your frame..
