hazza2805 Posted January 23, 2012 Report Share Posted January 23, 2012 (edited) My MAD Phase frame flexes A LOT, the rear brake has great hold but poor bite. The distance between brake mounts is a tiny 90mm, are there any 2 bolt boosters that will fit? The closest I have seen is the (ugly) Neon Booster which is 91mm. It doesn't look like there's a lot of material to file down to make it smaller though Cheers, Harry Edited January 23, 2012 by hazza2805 Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 23, 2012 Report Share Posted January 23, 2012 A cut-down Tensile 4-bolt booster? Quote Link to comment Share on other sites More sharing options...
hazza2805 Posted January 24, 2012 Author Report Share Posted January 24, 2012 Cheers, I hadn't thought of that! It seems my options are a filed Neon 2 bolt, or a cut down Tensile or Trialtech 4 bolt. Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted January 25, 2012 Report Share Posted January 25, 2012 (edited) What about the booster from some Evo2 mounts??? just a guess but I'd say that'd be narrow enough. http://www.tartybikes.co.uk/brake_clamps/magura_evo2_brake_adaptor_kit/c74p10934.html Try it, there only a tenner and if it don't fit I'm sure you could use them somewhere else, eh? EDIT: just found this a couple of topics up Them boosters are just nicer versions of evo2 boosters and a guy ^ reckons they have a 'eighty somthing mm' spacing, so try it out Edited January 25, 2012 by CC12345678910 Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 25, 2012 Report Share Posted January 25, 2012 Evo 2 boosters aren't really all that stiff though, so you may need to double up on them to get a booster worth using. Quote Link to comment Share on other sites More sharing options...
hazza2805 Posted January 26, 2012 Author Report Share Posted January 26, 2012 Cheers for the ideas guys, I think I will wait for the Tensile booster to be in stock at tarty. Harry Quote Link to comment Share on other sites More sharing options...
