Shimano Saint Cranks On An Inspired Hex
TokyoTrials
I'm just gonna do what Ali has done on his Hex and put 2 spacers on the drive side and 1 spacer on the non-drive side as it should be done along with a couple of washers on the axle to space out the chainring. Yeah, the left crank won't go fully, but if Ali has had no problems with his, then I think it should be ok. Failing that I will file down the chainring bolt mounts.
Thanks for all your help guys. You didn't need to help me, but you did. Much appreciated :)
  • 6 months later...
  On 8/9/2012 at 10:15 PM, TK92 said:
so does it make sense to use the longer 83mm axle BB width or stick with the standard 68-73mm, Im trying to fit some Saint cranks on a triton street and Im worried about the chain stay clearance
You should be fine with advice ali suggested.
after test fitting both the 68-73 and the 83 its definitely the 83mm DH that fits better, the spindle has the proper depth into each crank arm where on the 68mm version it does not and this is with the same amount of spacers 2 on the drive and 1 on the non drive. On my Triton the chain stays are about 10mm wider than the inspired fourplay.
