old'scoolfool Posted January 19, 2012 Report Share Posted January 19, 2012 has anyone got any tips the bugger wont budge Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted January 19, 2012 Report Share Posted January 19, 2012 Splined as in Middleburn or Shimano HG/UG/whatever? Quote Link to comment Share on other sites More sharing options...
N.Wood Posted January 19, 2012 Report Share Posted January 19, 2012 Actual splined cranks: Take lock ring off, use a mallet and penetrating fluid. Threaded / screw-on cranks: Take a look on the Tartybikes website for video help. Quote Link to comment Share on other sites More sharing options...
old'scoolfool Posted January 19, 2012 Author Report Share Posted January 19, 2012 (edited) Actual splined cranks: Take lock ring off, use a mallet and penetrating fluid. Threaded / screw-on cranks: Take a look on the Tartybikes website for video help. splined what an arse i meant threaded! sorry its a fixed trialtech sprocket on a try-all crank and obviously there are no grooves for any tool like a freewheel to keep it in place, usually a chainwhip and a vice works straight away when removing them from fixed hubs but this is not budging Edited January 19, 2012 by old'scoolfool Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted January 19, 2012 Report Share Posted January 19, 2012 http://www.tartybikes.co.uk/media/guides/maintenance_freewheel_and_sprocket_removal/m1.html Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted January 19, 2012 Report Share Posted January 19, 2012 (edited) splined what an arse i meant threaded! sorry its a trialtech 18t cog on a try-all try and obviously there no grooves for any kind of tool like a ffw i'm just damaging the teeth by trying You need piece of chain,bigger vice and 2-3ft long bar to fit on the crank http://www.tartybikes.co.uk/media/guides/maintenance_freewheel_and_sprocket_removal/m1.html Edit,damn you Ads Edited January 19, 2012 by ghostrider88 Quote Link to comment Share on other sites More sharing options...
old'scoolfool Posted January 19, 2012 Author Report Share Posted January 19, 2012 cheers guys, do i tighten the sprocket itself in the vice cause theres no freewheel type tool to clamp in and keep it in place like when removing a freewheel if that makes any sense? Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted January 19, 2012 Report Share Posted January 19, 2012 cheers guys, do i tighten the sprocket itself in the vice cause theres no freewheel type tool to clamp in and keep it in place like when removing a freewheel if that makes any sense? You don´t need freewheel remover if you use fixed sprocket just that piece of chain. Quote Link to comment Share on other sites More sharing options...
old'scoolfool Posted January 19, 2012 Author Report Share Posted January 19, 2012 You don´t need freewheel remover if you use fixed sprocket just that piece of chain. i meant an alternative but i think the problems my badly made chain tool i think it's had it i'll just buy a proper one and get it over with thanks for the replys Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted January 19, 2012 Report Share Posted January 19, 2012 chain tool Do you mean chain whip? Either way, that won't work - the technique in the video is the easiest. Quote Link to comment Share on other sites More sharing options...
