Rear Freewheel Help
AndrewEH1
Oh hell yeah. You'll really struggle to get it off without one. Even then they can be pretty tough.
Easiest way is generally to bolt the tool to the freewheel, clamp it in a vice (ubertight!) and get a bit of scaffold pole on the crank for maximum leverage. Should be more than doable that way.
I think there's a guide up on the Tarty site for it too, if that wasn't quite clear enough. :)
Edit; You can find the guide here
Yeah I know how to take one off, half the issue is that the freewheel is attached to a hub rather than a crank, I've got a length of pipe I use for cranks.
I need to buy some washers and a longer bolt to fit through a hub and the larger BB tool.
Gah, my bad totally forgot that it was on a hub about 2 seconds after reading :P
Same principle applies though, just makes it a little harder to bolt the tool in place! Is the hub threaded to take bolts? If so you should be fine to use those hub threads with a longer M6 (presumably) bolt since you only need to bolt the tool in relatively loosely (there's no real axial force going through it)
I've taken apart the freewheel and the hub (both needed a bit of a clean anyway) so I should be able to slide a bolt all the way through it easily...just need to buy the bolt.
The main issue was just checking whether I was being a retard or not.
Edited by AndrewEH1
