Magura Hs33 2011 Bleed Screw
Rowlly21
It's the little blanking plug on top. If you take the lever cover off, it's there underneath it.
It's the little black bolt-looking thing you can see on the lever. You'll also need to undo your barbed fitting so that there are 3 threads showing outside of the lever body - this lines the O-rings on the barbed fitting up with your bleed port, allowing fluid in/out.
