Shroud Nut And Olive Question
davidbarr
Hello. I'm getting rid of my braided hose and Buying a plastic hose with two shroud nuts and two olives. I've fitted barbed fittings to hoses before but not sure how to go about fitting the shroud nut and olive. Do I need to buy magura clamping blocks, or can you fit them by hand?
Any help appreciated. Thanks.
Slide the shroud nut onto the hose, then the olive, then tighten, done. (Y)
