williams Posted January 14, 2012 Report Share Posted January 14, 2012 hi everyone. I own a onza pro 2011. Let's get to the point... I was ridng yesterday and it was really cold ( like -9 c ) and i was jumping around, and then suddenly my cranks just stopped, and now i can barly rotate them. i know that the problem isn't my freewheel. So what should i do? and what's my problem? please help! Quote Link to comment Share on other sites More sharing options...
ooo Posted January 14, 2012 Report Share Posted January 14, 2012 if your freewheel is definitely okay; could it be your bottom bracket ? have you taken the cranks and freewheel off and tried turning the axle ? Is your rear wheel turning okay ? more info on what you've tried or pictures might help people answer... Quote Link to comment Share on other sites More sharing options...
williams Posted January 14, 2012 Author Report Share Posted January 14, 2012 (edited) if your freewheel is definitely okay; could it be your bottom bracket ? have you taken the cranks and freewheel off and tried turning the axle ? Is your rear wheel turning okay ? more info on what you've tried or pictures might help people answer... hey, thanks for the fast reply! yes, im preatty sure it's my bottom bracket. but i haven't taken off the cranks. i can post a pciture, but i guess it doesn't show that much of the porblem..? thanks! *update* my freewheel isn't working properly! Edited January 14, 2012 by williams Quote Link to comment Share on other sites More sharing options...
zonazip Jake Posted January 14, 2012 Report Share Posted January 14, 2012 its proberly just the bb mate , though i cant see how it just locked up like that. if not it may be the bearings in the rear hub. if its none of those then way the bike in lol Quote Link to comment Share on other sites More sharing options...
williams Posted January 14, 2012 Author Report Share Posted January 14, 2012 its proberly just the bb mate , though i cant see how it just locked up like that. if not it may be the bearings in the rear hub. if its none of those then way the bike in lol thanks, but the rear wheel is removed and i can barly rotate the cranks. my freewheel at the front isn't spinning correctly and get stuck at some points. so i guess it's the freewheel. thank you and have a nice day! Quote Link to comment Share on other sites More sharing options...
kane666r Posted January 14, 2012 Report Share Posted January 14, 2012 Chap if your rear wheel is off, and you still cant move the cranks, then the bottom bracket is the problem, as your cranks should spin freely with out the chain on the freewheel, just a heads up Quote Link to comment Share on other sites More sharing options...
williams Posted January 14, 2012 Author Report Share Posted January 14, 2012 Chap if your rear wheel is off, and you still cant move the cranks, then the bottom bracket is the problem, as your cranks should spin freely with out the chain on the freewheel, just a heads up well my cranks can barly barly rotate without the chain etc. so would it be the freewheel or the BB? have a nice day! Quote Link to comment Share on other sites More sharing options...
peluca Posted January 15, 2012 Report Share Posted January 15, 2012 It's the BB 100% Quote Link to comment Share on other sites More sharing options...
TrialsIsHard Posted January 15, 2012 Report Share Posted January 15, 2012 Sounds like what's happened is the bearings in your BB have just died, and possibly the raceways exploded or something. Best thing to do is to take the BB out, and chances are it will never work again so take it all apart and see what's gone wrong. I doubt it's the cold that has made it break though.. Quote Link to comment Share on other sites More sharing options...
