Three Speed Setup With Gusset Double Six Cogs?
Chris Borneo
Yeah, it's doable. Gotta be set up well though, else you get nasty noises and shit shifting.
Might be worth mixing up some of the 2:1 and 1:1 SRAM/Shimano systems for general win in terms of cable pull, chuck in a front shifter for 3-speed glory and it's certainly doable if you play around with it.
You can take up 4t-worth of slack using a Trialtech sprung tensioner, so you could just sack the whole shifters/mech thing off and run one of those, then manually change gear if/when you need to. They've got a reasonable amount of lateral adjustment so there should be some way of making it work. If you're getting tight on space, you could always make the least-used sprocket something a little thinner like a Trialtech Race or Gusset 1-er. If you've got a Hope hub then digging in shouldn't be much of an issue, especially if it's not getting much action anyway.
Yeah, I've thought about just running a tensioner and shifting manually but I think I'm gonna want to change between the two quite a bit. Not all the time but it would be nice just to flick a thumbie and be in the right gear to cruise to the next spot. Main worry with running a shifter is that the 5mm gap between the sprockets is gonna knackered my chain.
