superjay Posted January 12, 2012 Report Share Posted January 12, 2012 ok so since i got back on the bike every day im using a new innertube. im landing smooth yet they still pop :/ so 2 things 1. where can i get cheap innertubes? 2.what tyre is best for stoping pinch flats? also before you ask im not even running low tyre presure yet it still keeps happening Quote Link to comment Share on other sites More sharing options...
forteh Posted January 12, 2012 Report Share Posted January 12, 2012 Have you ground your rims? If so, check the bead edge where the tyre sits, if there is a sharp edge there it will cause pinches. Run round it with a file or carefully with a grinder so that its a rounded edge and you may find the pinches stop happening Quote Link to comment Share on other sites More sharing options...
Duncy H Posted January 12, 2012 Report Share Posted January 12, 2012 Or buy decent large tubes that aren't cheap and stretch cause they are too small so pop easily. Quote Link to comment Share on other sites More sharing options...
superjay Posted January 12, 2012 Author Report Share Posted January 12, 2012 I been buying innertubes of tartybikes and it's just to costly that's why I want cheap. And I felt round my rim edge it was smooth :/ Quote Link to comment Share on other sites More sharing options...
forteh Posted January 12, 2012 Report Share Posted January 12, 2012 I been buying innertubes of tartybikes and it's just to costly that's why I want cheap. And I felt round my rim edge it was smooth :/ Is your rim tape intact? Rubbing on the edges of the rim drillings will also weaken a tube so that when you pressurise it by landing it splits at the thin point. Do you still get pinches at lower pressures? Also might be worth chucking some talcum powder in the tyre when you put a new tube in, it helps the rubber slide over itself and can help stop pinches. Quote Link to comment Share on other sites More sharing options...
superjay Posted January 12, 2012 Author Report Share Posted January 12, 2012 At low pressure it's worse. Rim tape is fine That's why I think it's the tyre side wall just not up to the job Quote Link to comment Share on other sites More sharing options...
