Squealing Discs
ogre
this is the exact method i have been using for a long time, not really had any problem's using brake cleaner even though a lot of rider's say never to use brake cleaner on bicycle disc brakes, as it is designed for automotive use.
the only time this won't work is if the friction material on the brake pad itself is thoroughly contaminated with some kind of oil or brake fluid, then there is absolutely no way of stopping your brake from honking like a bitch other than buying new pads!
