Heatsink Pads
isitafox
I got a load of cheap red and white material from Steve a while back and as my yellows on the rear are finally due for changing I wondered if anyone could advise which would be best to replace them with to save me messing about changing and bedding in 2 sets of pads??
Will be running them on a medium grind if that helps in CNC backings.
Went for the reds and it look like they should be up to the job. Just need to wear down a bit as my rim is at a slight angle to the pads so they're not quite hitting squarely, not making much noise yet but thats no bad thing, will just have to see how they go!
I had a set of reds, they were ok but I think a lot of that was due to my grind not being right. Been using a set of yellows for the last two years and theyre perfect (if a little loud), bite and hold are phenomenal; hold only falls off once the grind has gotten too dull. Ive got a set of white pads to use once the yellows finally peg it, the white and yellow compounds are identical apart from the colour.
I always had a fairly harsh (but not hugely sharp) grind with my reds, I think with my current grind (medium sharp) they would probably be a lot better.
