Laurence--Trials Posted January 9, 2012 Report Share Posted January 9, 2012 Right my rear brake is having trouble with sticky pistons, i have to push the lever back to its origonal place by hand, if i give it a fresh bleed again either with water or anti freeze will it sort the sticky pistons? Quote Link to comment Share on other sites More sharing options...
davidbarr Posted January 9, 2012 Report Share Posted January 9, 2012 Bleeding it again with water won't solve the problem. Take your pads off, pull your lever in and spray WD40 on the pistons. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted January 9, 2012 Report Share Posted January 9, 2012 Bleeding it again with water won't solve the problem. Take your pads off, pull your lever in and spray WD40 on the pistons. 1: Wd40 isnt a lubricant, it might get some gunk off the pistons if thats why they're sticking. 2: It has a chance of rotting the seals over time. Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted January 9, 2012 Author Report Share Posted January 9, 2012 Would copper grease do? Dont have any spray lube like gt85 etc.. Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted January 9, 2012 Report Share Posted January 9, 2012 Worth checking that Master Cylinder too yo' Bit of wet & dry (or just f**k the haters and grab a file like I did) and take down the piston a tad to make sure it's not expanded which can have similar effects Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted January 9, 2012 Author Report Share Posted January 9, 2012 Okay will do, thanks. Quote Link to comment Share on other sites More sharing options...
Blake Posted January 9, 2012 Report Share Posted January 9, 2012 You can use any sort of for the slaves and even for the master, I use vaseline personally Have used a thin oil I got from halfords before as well, anything to get them moving Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted January 9, 2012 Author Report Share Posted January 9, 2012 Vasaline sounds good, I'll use that. Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted January 9, 2012 Author Report Share Posted January 9, 2012 Thats strange, un did the clamps, tool the slaves out and dadaaa they no longer stick, thats strange? Lubed up everything anyway and gave the pads a clean Quote Link to comment Share on other sites More sharing options...
