Freewheel/crank Thread Problem
p_ruskin
A few months ago, my trialtech cranks threaded slowly and as the threads stripped the cranks slowly move round the freewheel,
Less than two months ago i got new freewheel and cranks and the same happened again today, but after two full rotations of the crank loose round the freewheel it tightened up again, and became ridable
But im very concious of riding now in case the threads rip out suddenly,
Has anyone else had the same problem? I will take the freewheel off and see if any of the threads are damaged, its just a bit annoying seeing as the cranks are pretty much new
Have you got a bash guard on between the crank and freewheel?
Yeah normal trialtech halfring, and the new TR freewheel, but it seems to have tightened it self up again, rode a full day afterwards and it hasn't budged, really strange
sound like its stripping again, did u put any grease on the thread when fitting ?
  • 1 month later...
Sorry for the bump. But, Paul has yours been fine ever since? or have you had to replace the freewheel and cranks? My echo freewheel has done it today and tightened up again, but i'm not sure if its safe
Id be weary of it nick, my cranks snapped off at the threads and had to get it replaced, i know it may put you off but i would give it a while and see if it does as it might be okay
