Stevey Posted January 6, 2012 Report Share Posted January 6, 2012 I have an Echo TR disc brake which is leaking from the caliper and requires a new piston seal. Does anyone know where I can buy a replacement? I have looked but had no such luck. Stevey Quote Link to comment Share on other sites More sharing options...
Greetings Posted January 6, 2012 Report Share Posted January 6, 2012 It's worth finding out if a Hope seal will fit. The slave is exactly the right size. Quote Link to comment Share on other sites More sharing options...
Stevey Posted January 6, 2012 Author Report Share Posted January 6, 2012 It's worth finding out if a Hope seal will fit. The slave is exactly the right size. Not sure if I can use Hope seals because Hope brakes use DOT fluid whereas the Echo uses Mineral Oil or will it work? Quote Link to comment Share on other sites More sharing options...
Azarathal Posted January 6, 2012 Report Share Posted January 6, 2012 I wonder how well a hope caliper would work on an Echo Lever using Hope seals in the lever? If thats possible? Quote Link to comment Share on other sites More sharing options...
Stevey Posted January 6, 2012 Author Report Share Posted January 6, 2012 I wonder how well a hope caliper would work on an Echo Lever using Hope seals in the lever? If thats possible? I think that would be possible but it would cost a bit of money to get a new caliper and seals. I just want to replace the caliper piston seal but I don't know where to get a replacement. Stevey Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted January 6, 2012 Report Share Posted January 6, 2012 Not sure if I can use Hope seals because Hope brakes use DOT fluid whereas the Echo uses Mineral Oil or will it work? it will work in this direction because mineral oil isn´t as agressive as DOT.It wouldn´t work the other direction though. Quote Link to comment Share on other sites More sharing options...
Stevey Posted January 6, 2012 Author Report Share Posted January 6, 2012 it will work in this direction because mineral oil isn´t as agressive as DOT.It wouldn´t work the other direction though. Oh right cheers, I wasn't sure so I guess I will buy the Hope seal then because it is the same size. Thanks Stevey Quote Link to comment Share on other sites More sharing options...
Greetings Posted January 7, 2012 Report Share Posted January 7, 2012 Oh right cheers, I wasn't sure so I guess I will buy the Hope seal then because it is the same size. Thanks Stevey The inner diameter is the same. Whether they will fit the caliper is a completely different matter. Tarty should know. Quote Link to comment Share on other sites More sharing options...
Stevey Posted January 7, 2012 Author Report Share Posted January 7, 2012 The inner diameter is the same. Whether they will fit the caliper is a completely different matter. Tarty should know. I was woundering that so I have sent them an email to make sure but it should fit seen as they have the same caliper. I just hope that it work. Quote Link to comment Share on other sites More sharing options...
Greetings Posted January 7, 2012 Report Share Posted January 7, 2012 I was woundering that so I have sent them an email to make sure but it should fit seen as they have the same caliper. I just hope that it work. They don't have the same caliper. The Hope is a Hope and the Echo is a erm.. Echo. Quote Link to comment Share on other sites More sharing options...
Stevey Posted January 7, 2012 Author Report Share Posted January 7, 2012 They don't have the same caliper. The Hope is a Hope and the Echo is a erm.. Echo. The Echo caliper is the same as the Hope Mono Trial caliper Quote Link to comment Share on other sites More sharing options...
Greetings Posted January 8, 2012 Report Share Posted January 8, 2012 The Echo caliper is the same as the Hope Mono Trial caliper No it isn't Quote Link to comment Share on other sites More sharing options...
Stevey Posted January 8, 2012 Author Report Share Posted January 8, 2012 (edited) No it isn't It has the same piston size and seal size and is based very closely on the Mono Trial caliper so it pretty much is the same inside but with a slightly different external appearance. Edited January 8, 2012 by Stevey Quote Link to comment Share on other sites More sharing options...
philgresty Posted January 8, 2012 Report Share Posted January 8, 2012 It has the same piston size and seal size and is based very closely on the Mono Trial caliper so it pretty much is the same inside but with a slightly different external appearance. it has a different piston size, by a few mm's, hence it not being as powerful as the mono trial Quote Link to comment Share on other sites More sharing options...
Ali C Posted January 8, 2012 Report Share Posted January 8, 2012 not quite. The caliper is very similar, but is forged rather than cnced like the Hope one, they do use the same size piston and seals though. The difference in power is due to the lever having a 14mm piston (rather an a 8 or 9mm in the hope) they do compensate for that by placing the lever pivot closer to the piston to give a higher leverage ratio though. The Echo rotors are also made out of a harder metal which means they take a long time to bed in. Quote Link to comment Share on other sites More sharing options...
Greetings Posted January 8, 2012 Report Share Posted January 8, 2012 they do compensate for that by placing the lever pivot closer to the piston to give a higher leverage ratio though Finally! I was trying to solve this puzzle for a while now, blamed my eyesight for not seeing the difference in master cylinder diameter between the rim and disc brake. Never measured them. Recently installed a TR disc lever onto an HS33 and that made it slightly spongy and quite a lot more powerful. With some stiff forks like Trialtech or Bonz, it could actually be a very good upgrade. Quote Link to comment Share on other sites More sharing options...
Stevey Posted January 9, 2012 Author Report Share Posted January 9, 2012 The caliper is very similar, but is forged rather than cnced like the Hope one, they do use the same size piston and seals though. That is what I was trying to say about the caliper because I need a new seal for it and someone suggested the Hope seals and then this debate about wether it would fit or not started. Now it is sorted that they will fit, I just hope that the seals will work. Cheers for helping! Quote Link to comment Share on other sites More sharing options...
