bagre15 Posted January 6, 2012 Report Share Posted January 6, 2012 Hi, I'm planning to get rear disc brake (hope tech trial) with a 160mm rotor for my because simple 20", but I'm not sure about the caliper size. Wich caliper should I get 3# or 5#? What is the diference between them? Thanks and sorry about any errors in my writing Quote Link to comment Share on other sites More sharing options...
Azarathal Posted January 6, 2012 Report Share Posted January 6, 2012 From what I remember it'll be the #5 caliper. Bascially the #5 caliper will be 180mm if run on the forks or 160mm on the rear wheras a #3 wil be 160mm on the forks and 140mm on the rear. Quote Link to comment Share on other sites More sharing options...
bagre15 Posted January 6, 2012 Author Report Share Posted January 6, 2012 From what I remember it'll be the #5 caliper. Bascially the #5 caliper will be 180mm if run on the forks or 160mm on the rear wheras a #3 wil be 160mm on the forks and 140mm on the rear. What if I want to run 160mm on the rear? My rear mount is IS standard Quote Link to comment Share on other sites More sharing options...
Azarathal Posted January 6, 2012 Report Share Posted January 6, 2012 I just told you to run a #5 and gave reasons why... Quote Link to comment Share on other sites More sharing options...
bagre15 Posted January 6, 2012 Author Report Share Posted January 6, 2012 I just told you to run a #5 and gave reasons why... Sorry I didn`t read well. But I was looking a tarty and I thought the 5# would be for Koxx frames with 160mm rotor. Can you explain the difference between 5# and 3# please? Quote Link to comment Share on other sites More sharing options...
Azarathal Posted January 6, 2012 Report Share Posted January 6, 2012 Whoops ignore me. Sorry you need a #3 caliper. I'd got the numbers mixed up Quote Link to comment Share on other sites More sharing options...
bagre15 Posted January 6, 2012 Author Report Share Posted January 6, 2012 Whoops ignore me. Sorry you need a #3 caliper. I'd got the numbers mixed up Ok, thanks again Quote Link to comment Share on other sites More sharing options...
dave33 Posted January 8, 2012 Report Share Posted January 8, 2012 the difference is 20mm on disc rotor size, the koxx has a plus 20 mount which means its in the right place for a bigger rotor so if u had a koxx with plus 20mm you would run a number 5 with 160mm rotor but if you put the nunber 5 on an iso you would need a 140mm rotor you can also buy plus 20 adaptors etc from hope and some other company but in ur case you need a number 3 for the rear if you want 160mm Quote Link to comment Share on other sites More sharing options...
