Echo Tr Lever
Gee-Campbell
Hey, just wondering, has anyone else had any problems with their echo TR levers? for a few months now most the fluid i put in seems to leak out at the lever, but just a bit a day until eventually the brake doesn't work anymore.
Ive checked the seals and they seem fine, i use water and a bit of vodka to bleed the brake, all the bolts seem tight enough to not let any fluid through.
Any ideas on how i can fix this, or is it just the lever? ive heard this has happened to people before with this lever.
apparently echo levers don't hold a water bleed very well, although i've never tried it myself.
i use monty oil which is thinner than standard maggie oil, but thicker than water and it's not leaked yet, fingers crossed!
mine is also playing up but its not leeking, just wondering if anyone knows why mine wont set up properly :/
If your on about problems with the setup of the cylinders, its maybe because of the rim your using. I think they are designed for wide trials rims something like 42mm wide and over if you have 100mm space between the 4-bolt mount on your frame. Thats why some people buy echo levers and use magura hs33 cyclinders
