Trialtech Fork Help
cunny12345
Hi guys, the problem i have is that when i fit my old forks (echo's) not quite sure what its called but i put the rubber/plastic bit in the top which has two diffirent diameters for one part of it that goes between the fork and the headset to stop it moving around, i put that on my trialtechs, the top is then fine but the bottom of the fork seems to have a gap and is able to move around, it seems that the whole fork tube on the trialtech has the same diameter but on the echo the tube goes slightly bigger at the bottom so it gives it a more secure fit and stops it from moving, anyone got any suggestions on what to do to be able to stop the movement/free play on my trialtechs?
is there any plastic bit/washer i can buy to stop this?
Matt.
Sorry if its not that clear. .
Edited by cunny12345
