How To Set Up Hopes?
p_ruskin
Got a new frame the other day, and its disk only:(
I have never been a fan of them as i have never had one that has worked,
Tried to set this one up, and the rotor rubbed on the far pad, so i put spacers in and it still did, even after 3-4mm of spacers it was still rubbing on the far pad and preventing the wheel from spinning.
The lever likes to adjust itself with every pull and for the brief few moments it worked and was rideable, it had no hold at all
What am i doing wrong? and how can i fix this,
cheers
Mine took a lot of fiddling, patience, swearing, playing around with different washers...
Push the pistons all the way in, use a flat head screwdriver and push one pad onto the other to push the piston in. Then put in the selected washers to get the caliper sat so the rotor is central. Then pump the lever, see if the pads hit it square, and if it rubs.
I had to keep doing that, until I got the combination of washers. Even took a file to the mounts on my frame as I am yet to get it faced! Had to do this for the front and rear disc too!
Just take your time with it. Also make sure the rotor and pads aren't contaminated.
