How To Fix A Leaking Echo Tr Brake Lever
SAB
IF its definitely the lever, remove from the bike and rest of bike.
  • Remove lever blade
  • Poke a 1.5mm allen key into hosing hole to push piston out.
  • With a pick/ skewer remove the old o-ring from the piston carefully.
  • Clean the piston and bore well.
  • Buy this seal
  • Re-fit together, and lube with a lithium or silicone grease.
  • Re-bleed.
Link to bleeding and servicing magura
