weebryan Posted December 24, 2011 Report Share Posted December 24, 2011 Is there any spacers that can buy that go on top of sloping stem to make it straight so i can use normal top cap and also put spacers above the stem to try out before i cut the steer tube to correct lenght Or will i buy a 50mm spacer and cut the angle in? Quote Link to comment Share on other sites More sharing options...
Blake Posted December 24, 2011 Report Share Posted December 24, 2011 Don't think you can buy any that are already sloping, however you should be able to make your own modification to any headset spacer and it should work Quote Link to comment Share on other sites More sharing options...
craigjames Posted December 24, 2011 Report Share Posted December 24, 2011 I just used a 50mm spacer and modded it to fit. Worked fine, just looked daft! Quote Link to comment Share on other sites More sharing options...
Canardweb Posted December 25, 2011 Report Share Posted December 25, 2011 I just used a 50mm spacer and modded it to fit. Worked fine, just looked daft! Yes Marc Vinco did the same with a 20 mm spacer to get his TNN Top Cap to fit on his Monty stem. Quote Link to comment Share on other sites More sharing options...
