Need Help
cunny12345
Hi guys, i have just recieved a set of trialtech forks, i am getting them for christmas but i just wanted to see what they would look like with my rims, i went to put them on when i discovered a problem, my bolts in my wheel seem to be too big to fit through my forks, anybody know what i can do? oh yeah by the way i am using the Try-all rim with what looks like an adamant disk hub.
Cheers, Matt.
Most hubs are 10mm, trial techs have drop outs for a 9mm hubs, i have the exact same problem, just file away the drop out slightly, just half a mill on each side, problem solved. Wont cause any weakness to the fork either.
Or
If you have a lathe then pop the axle out and machine the axle down to 9mm.
Remove the axle and send it to tarty, they will put the axle in the lathe for around £10 and postage for just an axle will be cheap as chips. Saves you ruining a £100 set of forks for the sake of a easily replacable £15 axle.
Don't be worried about filing the dropouts, wouldn't affect the forks in any way :).
Josh.
Seconded.
Done it to both sets of mine. Only replaced the first set after they died where the legs join the crown.
It's not ideal, and you'll feel like a torturer doing it, but it's totally fine.
