Martin Reynolds Posted December 20, 2011 Report Share Posted December 20, 2011 As the title says. I've replaced the inside washer for a serrated one, the outside washer is an aluminium one with the steel serrated ring on it and the wheel bolt/washer isn't bottoming out on the axle. The axle is steel, so I can really tighten the bolt up, but as soon as i do a small pedal kick, the wheel moves and rubs the frame. Ideas? I've had to lash it up atm with padding the axle away from the frame Quote Link to comment Share on other sites More sharing options...
Rockman Posted December 20, 2011 Report Share Posted December 20, 2011 Snail cam? Chain tug? Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted December 20, 2011 Author Report Share Posted December 20, 2011 Snail cam? Chain tug? I cant use either, and that's not the point. They're only meant to help align the wheel, not prevent it from moving. Quote Link to comment Share on other sites More sharing options...
isitafox Posted December 20, 2011 Report Share Posted December 20, 2011 As the title says. I've replaced the inside washer for a serrated one, the outside washer is an aluminium one with the steel serrated ring on it and the wheel bolt/washer isn't bottoming out on the axle. The axle is steel, so I can really tighten the bolt up, but as soon as i do a small pedal kick, the wheel moves and rubs the frame. Ideas? I've had to lash it up atm with padding the axle away from the frame What is this? I didn't know you could get replacement serrated washers for the inside?? Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted December 20, 2011 Author Report Share Posted December 20, 2011 What is this? I didn't know you could get replacement serrated washers for the inside?? Wheel bolt with washer, a similar one to what im using Quote Link to comment Share on other sites More sharing options...
Rockman Posted December 20, 2011 Report Share Posted December 20, 2011 what frame? Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted December 20, 2011 Author Report Share Posted December 20, 2011 what frame? Born Ultimatum 26" 2011 Quote Link to comment Share on other sites More sharing options...
Rockman Posted December 20, 2011 Report Share Posted December 20, 2011 Born Ultimatum 26" 2011 How can you not use snail cams then? Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted December 20, 2011 Author Report Share Posted December 20, 2011 How can you not use snail cams then? On the frame yes, but not on the hub I'm using..... Quote Link to comment Share on other sites More sharing options...
ezgonzo Posted December 20, 2011 Report Share Posted December 20, 2011 (edited) what hub are you running?, i'm presuming the reason why cam's are out of the question is because your hub has a 135mm axle and the frame spacing is 135mm, if thats the case depending on your hub you could file down the axle ends 3mm on both side's to then be able to run cam's without having to pull the dropout's apart, or you could just run a cam on the drive side, it's not ideal and you will have to pull the dropout's apart a little bit when fitting the wheel but it won't cause any issues apart from being a little bit awkward. also inregards to cam's not stopping the wheel from moving, i had the same issue as you with my zhi z3 when i first built it up, but once i did a bit of fileing to the axle spacer's on my echo hub and fitted cam's the drive side stopped getting pulled forward, hope that helps. Edited December 20, 2011 by ezgonzo Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted December 20, 2011 Report Share Posted December 20, 2011 just run the snail cams on the outside of the frame like i do: Quote Link to comment Share on other sites More sharing options...
ezgonzo Posted December 20, 2011 Report Share Posted December 20, 2011 unless he was to get a file to the dropout's aswell i'm sure that cam's would'nt work on the outside. Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted December 20, 2011 Author Report Share Posted December 20, 2011 what hub are you running?, i'm presuming the reason why cam's are out of the question is because your hub has a 135mm axle and the frame spacing is 135mm, if thats the case depending on your hub you could file down the axle ends 3mm on both side's to then be able to run cam's without having to pull the dropout's apart, or you could just run a cam on the drive side, it's not ideal and you will have to pull the dropout's apart a little bit when fitting the wheel but it won't cause any issues apart from being a little bit awkward. also inregards to cam's not stopping the wheel from moving, i had the same issue as you with my zhi z3 when i first built it up, but once i did a bit of fileing to the axle spacer's on my echo hub and fitted cam's the drive side stopped getting pulled forward, hope that helps. I've already done the non-drive side and got a snail cam on that. I cant do the same for the drive side because the axle is too short, and would barely sit in the frame if i used a snail cam. And i'd have to force the frame apart, which i dont like doing. I doubt i could use a snail cam on the outside either, for a start it'd be pulling against the bolt rarther than the axle, achieving very little. And the way the dropouts are shaped, i doubt it'd fit Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted December 21, 2011 Author Report Share Posted December 21, 2011 Picture of lash up. Ive used some strips of metal to hold the axle in place Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted December 21, 2011 Report Share Posted December 21, 2011 Picture of lash up. Ive used some strips of metal to hold the axle in place What hub you using mon Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted December 21, 2011 Author Report Share Posted December 21, 2011 What hub you using mon Echo with the fixed 6 speed cassette. 05' or 06' i think Quote Link to comment Share on other sites More sharing options...
terry26rims Posted December 22, 2011 Report Share Posted December 22, 2011 quick release or axle bolts? Quote Link to comment Share on other sites More sharing options...
weebryan Posted December 22, 2011 Report Share Posted December 22, 2011 (edited) If its a 135mm axle and a 135mm frame dont add any washers Make sure when you tighten the axle bolts, the bolts/washer dont bottom out on the axle the bolts may feel tight but the washer only slightly touches on frame i had this once, just had to file the axle ends very slighty beacuse the frame had worn slightly were the washer sits and bottom out and wheel was moving even with snail cams I can see yours has gone the same, will only get worse until they properly tighten up File a small bit at a time and make sure the axle bolt starts ok after each time and keep internal threads clean from metal shavings when re-starting them or you will need a tap Edited December 22, 2011 by weebryan Quote Link to comment Share on other sites More sharing options...
ezgonzo Posted December 22, 2011 Report Share Posted December 22, 2011 (edited) after having a quick look @ some pics of your hub, it looks quite possible that you could file the end caps down ( judging by the very few pics i managed to find ), which would reduce the overall hub lenght allowing room to fit cam's aswell as allowing the axle to seat further in the dropouts, however this method would only work though if the part of the axle that is covered by the end caps is still 10mm in dia, hope that makes sence . edit: i just read my first post and i meant to put the axle end caps instead of axle ends my bad :$ . Edited December 22, 2011 by ezgonzo Quote Link to comment Share on other sites More sharing options...
stuie Posted December 22, 2011 Report Share Posted December 22, 2011 ever thought of trying to make a plat the shape of the gusseting you have there so you can place that in first the befor the bolt so it will not slip forward at all. Quote Link to comment Share on other sites More sharing options...
onzatrip Posted December 22, 2011 Report Share Posted December 22, 2011 Had a similar issue with my bionic and running a onza 6 speed hub o filed the endcaps on the hub so I could also fit cams and that worked a treat!!! Quote Link to comment Share on other sites More sharing options...
