What Frame Is Best For 26"
hiya
what frame is the best for 26" cause i will build 1 in mine spear time because i
have a ashton justice :blink:ashton justice
bit off a dead end question that, everyone has their own preference there's no one straight out of the box frame that's perfect for everyone
it would help it you mentioned the style of riding, your height etc otherwise i doubt anyone will bother to help you
You asked what frame is best for 26" (and i assume this is in reference to the wheel size). I would suggest the best frame for 26", is one that is intended to run 26", then your 26"s will fit in your 26" frame adequately.
If you put 26"s in a frame designed for either 20"s or 24"s then you'll be upset when it does not work, so in order to allow your 26"s to fit properly, you need a frame that is designed to accommodated 26"s, so really you should just pick from the wide selection of 26" accommodating 26" frames.
  • Like 2
hiya
not being rude or a knob or owt, but thats like saying how long is piece of string? its down to personal choice
the best frame is the one your riding! my best riding is always done on the bike i am on at the time.
If you are looking for a new frame then it is worth working out what it is about your last frame you dont like. If you are new to trials decide on what sort of trials you wanna do and then go on some rides with people and try out their bikes.
sorry but i only ride a mod bike, but if you just want a good frame then look a bit on tarty. for an example, this one looks ok: click here and this is the fram that "Neil Tunicliffe" uses ( he's my favourite rider)
Edited by williams
