josh da onza t-pro rider Posted December 18, 2011 Report Share Posted December 18, 2011 when i tighten up the headset so it stops wobbling the steering goes tight what could i do to stop this please help Quote Link to comment Share on other sites More sharing options...
davidbarr Posted December 18, 2011 Report Share Posted December 18, 2011 Tighten it to an extent where it doesn't wobble but the steering doesn't feel too tight. If you can't do this without the steering being too tight, then just ride, and it should start to loosen up a bit. Quote Link to comment Share on other sites More sharing options...
Chris Borneo Posted December 18, 2011 Report Share Posted December 18, 2011 (edited) If your headset is super tight but it still rocks, it probably means something's not alighned or seated right. It might settle down with a bit of use but you're best checking your cups are in straight and even that all the components have been intalled correctly. I've seen a few people put headsets together with bits in the wrong way round. I've done it myself with just a thin plastic seal in the wrong way up, I had the same problem. Edited December 18, 2011 by Chris Borneo Quote Link to comment Share on other sites More sharing options...
