What Have I Done Wrong
Mockett
whits rebuilding my frame (onza 320) whitch has rear disk tabs so i assumed it would acomidate a rear disk but there's no space for the disk the wheel is on straight and it is 100%true see attachedpost-21020-0-12602900-1324125787_thumb.j photos any advice would be great
the dis rubs on the frame
the disk rubs on the frame
I had the same issue with mine on an echo hub with my Onza Comp. Rubbed crazily lots on the frame.
Ended up putting a spacer on the disk side but it was awfully hard to put in the frame, then it was solid to set the rear disk up as the frame didn't bend out straight, it bent out at an engle so the caliper and rotor wasn't straight, absolute nightmare to set up so went back to rear maggy and haven't looked back lol.
I wonder if you could machine 6mm from the disk tabs and get it working lovely.
Considering the disc tab is probably only about 8-10mm, i dont think it would be wise :P
For a winning disc set up on an onza frame, use:
  • An Echo TR Disc rear Hub.
  • Echo TR Sprocket ( centralized teeth mean no chain rub )
  • The use of 1 Snail Cam on the non drive side (In between the frame and hub, as per the conventional way snail cams are located)
This means that the disc side is correctly spaced from the frames disc tabs.
I know it works as I've done this very method fitting a hope mono trial to my Ice 2 frame using a TR disc hub.
Edited by Echo Lite 09
