Refitting Hose To Lever Help
dannytrialskid
Split my hose yesturday. Used a stanley knife to cut the hose and cut the hose off of the lever. I have tried putting it back on but its so tight to get on there. Have tried heating up the end of the hose in boiling water and that didn't work either.
Any tips? Trying to get done asap because am riding tonight. :/
Do you have tools?
Get a block of wood, 5 cm cube would do it, drill into it a hole that's the width of the hose, cut this exactly in half with a saw.
Place the hose in the hole, clamp this in a clamp, and then hammer the fitting in.
So yeah, you need to make those. It will make this job roughly 100% easier.
