Billers Posted December 14, 2011 Report Share Posted December 14, 2011 Hey, ive recently started trials, i can do the bare minimum, although i do have a friend teaching me (who is awesome) i dont wanna rely on him as he has better things to do. i struggle doing most things on the back wheel, i want to learn how to jump and hop up walls on the back wheel, not big walls but just get the technique. any ideas how i can do this? thanks Quote Link to comment Share on other sites More sharing options...
TrialsIsHard Posted December 14, 2011 Report Share Posted December 14, 2011 Watch lots of videos and analyse technique, slow mo's are also good Quote Link to comment Share on other sites More sharing options...
Billers Posted December 14, 2011 Author Report Share Posted December 14, 2011 Watch lots of videos and analyse technique, slow mo's are also good okay, thanks alot Quote Link to comment Share on other sites More sharing options...
Josh allsworth Posted December 14, 2011 Report Share Posted December 14, 2011 im finding it hard aswell, i can do big drops just not big hops. Quote Link to comment Share on other sites More sharing options...
ooo Posted December 14, 2011 Report Share Posted December 14, 2011 check out some of the videos in my sig, also if you ask a more specific question, im sure someone will be able to give you a really helpful answer. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted December 16, 2011 Report Share Posted December 16, 2011 www.trashzen.com 5 Quote Link to comment Share on other sites More sharing options...
MiuSliS Posted December 16, 2011 Report Share Posted December 16, 2011 Wood's right check trashzen, but also remember that good foundations on 2 wheels are also not to be missed. That will always help once you move to 'advanced' hoping. Quote Link to comment Share on other sites More sharing options...
o0jack0o Posted December 21, 2011 Report Share Posted December 21, 2011 Hey buddy, As with most things a good basic skill set will enable you to progress you're skills quicker; i would recommend focusing on getting track stands sorted. You won't be able to do to much if you don't have a good balance/stance so make sure you're ace at it. Then, as i did, just try practicing rocking between front and back wheel only coming off the ground by a few centimetres. After this begin to increase the size when rocking backwards a little. Soon you'll be able to add a small kick in; after a while you should be able to do a couple of small kicks. You may not come off the ground but only roll forward, this does'nt matter just add a little more kicking power and lift more with you're arms. When you have this nailed try and get straight up to a hop without using endo else you will be restricted with what you do (normally easiest when rolling slowly). As you progess add more power and try to improve technique by watching videos ect. Top tip would be to make sure you point you're toes down on the pedals when kicking as this makes you sort of lift the bike (as you do when you bunny hop) Hope this helped =) Jack Quote Link to comment Share on other sites More sharing options...
BurlyBox Posted December 22, 2011 Report Share Posted December 22, 2011 I started by hopping on the back wheel and then getting better balance and control so i felt confident enough to try a pedal hop/kick without thinking im going to fall off. once i had the balance and control i could pedal hop pretty well and once you learn that you will realise hopping up walls and things like that is pretty much a pedal hop but with more height to get you up it. I dont know if this will help you but ive been riding about 6 months and this is how i learnt the basics. Quote Link to comment Share on other sites More sharing options...
skidmark Posted December 22, 2011 Report Share Posted December 22, 2011 i started out by getting my technique on curbs and really small stuff and then once i was comfortable with what i already done i moved on to something a little bit bigger Quote Link to comment Share on other sites More sharing options...
Jimmy 04 pitbull Posted December 23, 2011 Report Share Posted December 23, 2011 all us riders have things that we're not as good at as others, but it just takes time, practice, patients and commitment. Another good way to learn the tricks of the trade is to come along to various rides that are put on i.e. DJ memorial ride, that's the best way i think. Quote Link to comment Share on other sites More sharing options...
Billers Posted December 26, 2011 Author Report Share Posted December 26, 2011 thanks everyone, using all the advice youve given, thanks again Quote Link to comment Share on other sites More sharing options...
