onza pro series guy Posted December 14, 2011 Report Share Posted December 14, 2011 (edited) I recently picked up a set of White 07 Hs33s, they are evo2 kits and I run normal 4bolt mounts on the rear, I have started modifying the actual clamps and they seem to fit the frame. Is there anything I should watch for which might lead to damage once they are in use though stress? Im sire this must have been done before so has anyone got any tips or pointers really? TO CLEAR THINGS UP I'M ASKING ABOUT TURNING EVO 2 CLAMPS INTO 4 BOLTS Thanks Dave Edited December 14, 2011 by onza pro series guy Quote Link to comment Share on other sites More sharing options...
Azarathal Posted December 14, 2011 Report Share Posted December 14, 2011 Remove the evo2 mounts and use 4bolt as usual? Quote Link to comment Share on other sites More sharing options...
WIGAN ?? Posted December 14, 2011 Report Share Posted December 14, 2011 safe to say this confused the f**k out of me, why would you run evo mounts on a 4 bolt frame ? 1 Quote Link to comment Share on other sites More sharing options...
old'scoolfool Posted December 14, 2011 Report Share Posted December 14, 2011 Im sire this must have been done before so has anyone got any tips or pointers really? Thanks Dave doubt anyones that stupid but expect your frame to crack in the brake mount area at some point Quote Link to comment Share on other sites More sharing options...
JD™ Posted December 14, 2011 Report Share Posted December 14, 2011 Everyone in 'missing the point of the question' shocker. You mean running 4 bolts through an Evo 2 clamp right? As in not running the shoulders on the top, just running a bolt into the top hole of the mount? I'm sure I've seen it done before too, but for the sake of a few quid for clamps it seems a worthless potential risk (though I'm not sure that we should be waving goodbye to your frame instantly ) Quote Link to comment Share on other sites More sharing options...
onza pro series guy Posted December 14, 2011 Author Report Share Posted December 14, 2011 Everyone in 'missing the point of the question' shocker. You mean running 4 bolts through an Evo 2 clamp right? As in not running the shoulders on the top, just running a bolt into the top hole of the mount? I'm sure I've seen it done before too, but for the sake of a few quid for clamps it seems a worthless potential risk (though I'm not sure that we should be waving goodbye to your frame instantly ) This^^ replacing the quick release with a bolt and a washer. I'm sorry if the question made me sound like some sort of special but it was rushed. Its obviously not perminant but my bank balence reads £1.29 at the mo I wouldn't have thought my frame would snap straight away as I am using Magura clamps as, well Magura clamps, just modifying the attachment method to what the frame requires? Quote Link to comment Share on other sites More sharing options...
Mark W Posted December 14, 2011 Report Share Posted December 14, 2011 I used them bolted up onto 4-bolt mounts before (using a long bolt to go straight through the top of the Evo 2 kit into the actual mount on the frame) and it was fine, although I didn't have any adjustment which wasn't that convenient Quote Link to comment Share on other sites More sharing options...
onza pro series guy Posted December 14, 2011 Author Report Share Posted December 14, 2011 I used them bolted up onto 4-bolt mounts before (using a long bolt to go straight through the top of the Evo 2 kit into the actual mount on the frame) and it was fine, although I didn't have any adjustment which wasn't that convenient Yeah I cut the extended 'shoulder' off so I could use the bolts that came with it, luckily the placement seems ok hence my 'seems to fit the frame correctly'. Please excuse my rushed, confusing and grammatically incorrect question everyone!! Quote Link to comment Share on other sites More sharing options...
isitafox Posted December 14, 2011 Report Share Posted December 14, 2011 When you have £12 come see me for some TR mounts! Quote Link to comment Share on other sites More sharing options...
onza pro series guy Posted December 14, 2011 Author Report Share Posted December 14, 2011 When you have £12 come see me for some TR mounts! Haha will do! Quote Link to comment Share on other sites More sharing options...
