chris4stars Posted December 13, 2011 Report Share Posted December 13, 2011 (small bolts to strip for an example). surely with a fixed clamp, the small bolts will only need to be as tight as your regular disc brake caliper bolts? nowhere near as tight as a magura set up, with bolts not needing to clamp anything with as much force... maybe im seeing this wrong... a closed system and a method of angling the slaves up/down and i think they are onto a winner... as far as i see it, if the pad adjustment for getting the pads closer/further from the rim is as simple as a few turns, an open system just isnt needed could involve the slave having a locking pivoting system, or even something as simple as effectively an angled washer to place underneath the clamp? must be solutions to those problems Quote Link to comment Share on other sites More sharing options...
