Do You Need To Use Loctite To Secure Lgm In Backings?
Blake
Hello!
Basically I would like to know if it's absolutely adamant that you use one of the recommended adhesives in the little tnn book that comes with refills?
I was planning on using gorilla glue or will this not work?
Thanks in advance :)
Edited by DrStix
I've had a pad come out (original Coust material - check me out) before 'cos I did a shit-poor job of cutting and glueing it and nothing bad really happened. But yeah, the fit on TNN pads and backings is usually really, really good so any normal superglue will probably be ample.
Most super glues will do the job fine. Our "loctite" glue is flexible so the adhesion last a bit longer. I know of riders who do not glue their refill in and have not had issues. Although I high recommend glue.
The cavities in the backings are 4mm deep and as long as you don't set up your pads that far away from the rim. It's near impossible for the pads to come out of the backing.
Hello!
Being new I assume this is all about fitting refils in to brakes?
Just incase you dont know Loctite comes in many different forms and its best to use the corrcet one for each job.
http://www.loctite.co.uk/cps/rde/xchg/henkel_uke/hs.xsl/homepage.htm
Its fantastic stuff when you use the correct one. I have two in the shed, one allows you to dissassemble things the other you have no chance unless you heat it to 800C
Most superglues are not water proof, so once it starts to get wet it can degrade, depending on which one use use.
