Onza Zoot Fork And Brake Change Query?
mr.tattoo
Generally a vee will be a tad less bitey than a Magura but has epic amounts more hold. It can take a ride or two to get used to, but it's a lush feeling when you do and bite's not so essential on something streety like a Zoot. That said, if you're running a grind and a booster I doubt you'll see much drop in bite if you run a decent set of pads (but then you loose modulation in the same way a maggie does of course)
That said, there's always an element of personal preference involved here as some people always seem dead set that one is better than the other, though I highly suspect that's down to not having ridden a well set up vee/magura so 'preferring' the other. Horses for courses. If you can try a few brakes out then I'd advise it - whatever you get just spend the time getting it right and you won't go far wrong (Y)
thanks guys all im worried about is a few times ive laded on rear wheel and brake hasnt held enuf and its looped under me, i cant bare anuva trip to a&e lol. if a decent vee setup and decent pads will hold when needid then il go for that. never had a streety bike before so not sure how il like it lol not sure a grind will be great on a street bike as itl be on/off ? maybe a smooth rim and decent pads is the way to go for these typeof bike? i just dont wana hop on or off something and the rear give and shazam!
