Matt Vandart Posted December 7, 2011 Report Share Posted December 7, 2011 I am currently running a hope trials hub on my all mountain bike. This obviously has a disadvantage of gear spread (?) My question is: I have an 8speed cassette 11-32 and was wondering what was the biggest tooth step up can I get away with to cut out 2 gears and keep both the 11 and the 32. I hope that makes sense. Thanks in advance. Matt Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted December 7, 2011 Report Share Posted December 7, 2011 I am currently running a hope trials hub on my all mountain bike. This obviously has a disadvantage of gear spread (?) My question is: I have an 8speed cassette 11-32 and was wondering what was the biggest tooth step up can I get away with to cut out 2 gears and keep both the 11 and the 32. I hope that makes sense. Thanks in advance. Matt Try it and see! To be honest you may need to sack off the 32 though and run things a bit more close ratio. I think the maximum 'tooth step' you can get away with will depend on the gear in question. Going from a 29-32 will be less of a step than going from an 11-14 if you know what I mean. Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted December 7, 2011 Author Report Share Posted December 7, 2011 Ah I see, oki dokis, I was going to try it anyway just looking for info before hand so that I can gauge whether its my shit setting up skills rather than trying to do the impossible. Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted December 7, 2011 Report Share Posted December 7, 2011 Ah I see, oki dokis, I was going to try it anyway just looking for info before hand so that I can gauge whether its my shit setting up skills rather than trying to do the impossible. What ratios do you have to play with? I guess the best bet if you really need to go from 11-32 would be along the lines of 11-13-16-20-25-32 with 'tooth step' increasing (almost) incrementally as the sprockets get bigger. But yeah, to get from 11-32 in six steps may be asking a bit much of your chain and derraileur! Quote Link to comment Share on other sites More sharing options...
err Posted December 7, 2011 Report Share Posted December 7, 2011 (edited) i'd guess you could get away with a fairly big gap in sizes, have you seen the megarange cassettes with the massive 1st gear? like this: edit; that's a screw on in the pic, but i just put it up as an example of the jump in size Edited December 7, 2011 by err Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted December 7, 2011 Report Share Posted December 7, 2011 i'd guess you could get away with a fairly big gap in sizes, have you seen the megarange cassettes with the massive 1st gear? like this: edit; that's a screw on in the pic, but i just put it up as an example of the jump in size They use a special mech though, don't they? Quote Link to comment Share on other sites More sharing options...
ZeroMatt Posted December 7, 2011 Report Share Posted December 7, 2011 (edited) Did the same thing myself a while ago on a 11-28 cassette, found that removing the 12, 13 and 16t sprockets worked a charm. It ended up as 11-14-18-21-24-28. Edited December 7, 2011 by ZeroMatt Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted December 8, 2011 Author Report Share Posted December 8, 2011 Nice one dudes. Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted December 14, 2011 Author Report Share Posted December 14, 2011 It worked tidy beans! Quote Link to comment Share on other sites More sharing options...
