So What's The Deal With Closed System Disc Brakes...
planet x alan
Just gone dual disc on my 221, and as a temporary measure (till I find some mono trials/ tech trials reasonably priced) I've stuck the rear brake off my dirt jumper on. It's an Avid Elixr.
Now why is it when i took the dirt jumper in from the shed the wheel spun nice and freely. Put it on the monty and it's pretty much stuck on. Goes outside on it for 10 mins and it frees up.
Seems like something is expanding in the heat/contracting in the cold. The brake is 2 rides old (2 rides if you count taking the dirt jumper out and spending more time on the bmx twice). I heard of this happening on the old hope C2 brakes and here's my questions:
1. Exactly what's causing this to happen
2. Why does it not happen when the brake is being used extensively and generating its own heat.
3. Why have I never came across this running open system brakes and hs33s?
I know the open systems have the reservoir etc etc But I would assume it would make the brake feel slightly different momentarily.
