Help Removing Crank Arms
trialskidy
If the original crank extractor threads have stripped then the best way is to use a three leg puller; whether or not you will find one small enough though is another matter, you may well also have to grind the puller jaws to enable them to gain purchase on the crank arm. As already said, your LBS might have something available to get it off for you.
