G_! Posted December 4, 2011 Report Share Posted December 4, 2011 hi, just i want to know the way to do slow motion, i have a hd camera so i think i can do it... can i do this with Sony Vegas 7? how? i know to do the simple slow motion but that doesn't look awesome.. thanks Quote Link to comment Share on other sites More sharing options...
Revolver Posted December 4, 2011 Report Share Posted December 4, 2011 If you really want to do good slow motion you need to use a higher/slower frame rate on your camera. Then you play it back at the normal frame rate and it comes out slow. There's a technique in premiere to fill in gaps between frames but I've not tried it out. Also it's premiere. Quote Link to comment Share on other sites More sharing options...
ZeroMatt Posted December 4, 2011 Report Share Posted December 4, 2011 There's a technique in premiere to fill in gaps between frames but I've not tried it out. Also it's premiere. Twixtor does the same thing. Like revolver said though you'd be better off filming with a higher frame rate as motion estimation stuff isn't amazing and will get worse with the more new frames added. Quote Link to comment Share on other sites More sharing options...
aener Posted December 4, 2011 Report Share Posted December 4, 2011 As above - if your camera is a reasonably standard one, the best you can do is Twixtor. If you've got an expensive camera with the capability to do so, you'll want to up the frame rate. (250fps will give a much smoother slow motion than 50fps. It takes five pictures in the time it would normally take one.) Quote Link to comment Share on other sites More sharing options...
