Mtb Lights
AndrewEH1
I am planning to perhaps do some night rides at one of the local trail centres.
Obviously it is dark at the moment so I'll be needing a bright, efficient front light. For the back I'm planning a cheap red light just to ensure I am seen from behind.
Any recommendations?
It needs to have a good solid mount as I don't want it to fall off or rattle about too much.
Edited by AndrewEH1
I've always found Mag Lites to be under powered and over priced for what you get...
Not a bad point we get them for free at work so not bad for me.
Our local £1 shop sells these
post-30635-0-63763000-1322509654_thumb.j
We have a few for the kids for camping and they are very good and wouldnt be the end of the world if lost.
I recently got one of the XML lights from mtbbatteries.co.uk
I wasn't really up for buying a deal extreme/magicshine/other ebay bargain. I didn't want to have to wait for it to be shipped from Hong Kong and I had also heard different stories regarding the build and battery quality.
I found out about the MTBBatteries lights while searching the Singletrack World Forums for reviews of the deal extreme lights. I have used it on my road bike and also for XC and am very impressed! Yes it is twice the price of the cheap ebay offerings but I am happy I have supported a small UK based company and also have his backup if I have any problems. There is loads of info about all the different lights available on the STW forums (Y)
A lot of those XML lights are similar to each other. Go on ebay and search for something like CREE LED bike light along with either Q5, T6, XML, Ultrafire and you'll get loads of results. It's not just limited to the 4 I said, there's loads, they were the ones that came to mind first. Some have built in rechargeable batteries, some take AAs, some take AAAs, some come in pairs, some don't. LOADS!
Most of the lights are kind of similar - whether they're from ebay/deal-extreme/mtbbatteries or those ones from JE James. They're all the same design, with a few very subtle differences, none of which are really worth paying more for. The XML T6 is supposedly a brighter LED but I don't think it makes much difference. The only real difference is aftercare, apparently the mtbbatteries ones (and probably the JE James deal) have quite good support, and obviously they'll arrive quicker. Whether that's worth paying double is up to you - I didn't think so, so I ordered some from eBay.
http://www.ebay.co.uk/itm/New-Fashion-CREE-XML-XM-L-T6-LED-1600-Lm-Bicycle-Light-HeadLamp-HeadLigh-/150698078984?pt=UK_SportsLeisure_Cycling_Bike_Lights&hash=item23164e3308#ht_5377wt_1008
I paid £36 also, but I'm not sure if that was the same seller. Mine took 10 days to arrive, but I've got friends who waited 30 days!
As for the lights, they are B-R-I-G-H-T! They're fairly solid, I've got no concerns about build quality (though obviously they're not posh like Hope ones) and the mounts are solid enough. My only real criticism is that the light beam is quite focused, the main beam is only about a foot wide at a normal riding position (beam on the floor ~6 feet in front of me), which means I have to move my head around to light up different bits of the trail. This also means it's amazing for shining in the eyes of oncoming drivers and lighting stuff up from 200 yards away. I think some of the other variants may have different reflectors in which may be better.
I believe a single T6 Cree LED is only capable of producing up to ~1000 lumens so don't believe all the ebay stuff saying 99million lumens from a single LED. Realistically most people should be fine with 1000 lumens, I am getting on OK with just the mtbbatteries light on the handlebars although I sometimes wish I had an extra light on my helmet with a more focussed beam to light up where I am looking.
A useful feature to check is with any of the lights is what power settings it has, a lot of the cheaper offerings only have 3 settings, High, Low and flashing. The light I linked to has High, Medium, Low and flashing, I am always finding myself using the 50% power mode on easy/slow sections of trail to lengthen the battery life!
The Magicshine MJ872 is another light getting good reviews.
Would you say they're a bit over kill for a 3 mile commute to work?
It depends what the commute is like.
On the road bike if I am out on my own on pitch black country roads I often use the 50% medium power setting, if I am out in a group of other people or on roads with street lights I just stick to the 10% low setting. I only use the 100% setting off road.
Either way it will certainly make sure you get seen by other road users, I have had cars flashing me quite a few times :P
Excellent, how soon did they arrive? I have a halfords super bright LED, but it's just not dazzling enough. And it's all country roads with pretty dangerous drivers rushing to get home.
Thanks.
As long as he has them in stock I believe he posts them out the same day.
When I ordered mine he was waiting for a batch from his suppliers but he kept me up to date with emails and it was luckily only delayed by a few days.
I just checked their facebook page and on the 22nd he stated he had stock and was also due another batch this week so hopefully you won't have any delay (Y)
240 lumens? It's not 1999.
Lumens are a very poor measure on the brightness of a light as there are no industry standards when measuring. Some quote "potential output" based on the optimum configuration, some quote diode output in general (not after being soldered to the manufacturers circuit or power supply) and some quote brightness at 1 metre from the output.
Most chinese websites quote lumens as a best case scenario from the diode. What comes out of a claimed 1600 lumen light might only be a little brighter than that of a 300 lumen one from somewhere else.
In the case of the mj872 though, it's somewhat comparable to the hope vision 4. Not my own personal experience mind, but this website seems pretty reliable and has loads of lights in an easily comaparable chart. Should be a good port of call for anyone looking to buy a new light.
Well I've used both a Hope Vision 1 and a Magic Shine light and the Magic shine is many, many, times brighter. I don't know if it's 8 times brighter as quoted (It may well not be) but it's a daft comparison. The Chinese one is far brighter.
