Bleedng Maggura Hs33
benjie1992
could someone tell me the benefit of bleeding magurra hs33'S with water and antifreeze? and can i do it to standard hs33 set up?
Benefits: Free (well, antifreeze costs a little bit) to rebleed, you can do it wherever you like, and it's a thinner, lighter feeling fluid than the oil.
Drawbacks: unless you add antifreeze the brake will freeze in winter, and some pistons sometimes absorb a bit of water over time.
You can do it to a standard HS33.
Anti-freeze is apparently not particularly good for brakes though :\
I dunno, it's not eaten through the seals in my brake in the 3 years it's been since I last bled my brake.
The tubing in your car it runs through is also made from plastic, it hasn't eaten through those in the 11 years my car's been around for either.
