shercofray Posted November 17, 2011 Report Share Posted November 17, 2011 Does anyone run these as tempted to get some, however not sure on model and which would run best with a hs33? Cheers, Frazer Quote Link to comment Share on other sites More sharing options...
onza pro series guy Posted November 18, 2011 Report Share Posted November 18, 2011 Are pimplites rim brake compatible? Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted November 18, 2011 Report Share Posted November 18, 2011 Quote Link to comment Share on other sites More sharing options...
TrialsMan Dan Posted November 21, 2011 Report Share Posted November 21, 2011 I had Pimplites on my Ashton 24" I prefer MTB rims as opposed to specific trials rims, I have more confiddence in them. I very rarely hear of MTB rims failing, Atomlabs are the ultimate in strength even says on the rim tape they are 'Tough as Hell' plus Danny Mac uses them, do you need anymore convincing? Yes they are a bit heavier than trials rims but they will last a lot longer plus they hold a grind very well. I had mine for 10 months and had about 4 or 5 light/medium sharp grinds with no problems. But also remember it also depends on the quality of spokes and the wheelbuild. Quote Link to comment Share on other sites More sharing options...
Ali C Posted November 21, 2011 Report Share Posted November 21, 2011 for pretty much the same strength but a little lighter you could get a Spank Subrosa or if you want a little wider, the Spank Stiffy is the same weight as the Atomlab, just as strong and is 40mm wide. Quote Link to comment Share on other sites More sharing options...
