Alex Dark Posted November 15, 2011 Report Share Posted November 15, 2011 (edited) Hi there, need some help sorting a headset for someone... he says its the same as a Monty which is listed on Tarty as internal... but everyone else seems to call them semi-integrated. Its for a speedrace frame if thats any help, and no it isn't available normally so i can't call tarty etc. I'm 99% sure that the following headset would fit, but just to make sure... will it? Token Headset I know there are different angles which is the main reason im asking, and the guy doesnt have the tools to measure the angle. ( Campognolo 45/45 and some other 36/36 spec? ) Edited November 15, 2011 by Alex Dark Quote Link to comment Share on other sites More sharing options...
philgresty Posted November 15, 2011 Report Share Posted November 15, 2011 that token one is internal and is the same as montys, megamos and atomz use so thats gonna be the one, the campagnolo 45/45 headsets dont use cups, the bearings just sit in the frame, the same as a bmx headset, and also used on road/track frames. best bet is get the picture of the headtube to be sure, youll be able to tell from that Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted November 15, 2011 Report Share Posted November 15, 2011 Internal is often called semi-integrated. The reason we use 'internal' as there is also 'integrated', and that's too close to semi-integrated and causes confusion! Check wikipedia for more info. The angle doesn't matter with an internal headset (as the cups will match the bearings), only for integral. Quote Link to comment Share on other sites More sharing options...
pengsmelly Posted November 15, 2011 Report Share Posted November 15, 2011 I have already told kieran which headset to buy haha that one you linked should fit it no problem but james found his monty headset now as well so we guna give that to kieran to try. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted November 15, 2011 Author Report Share Posted November 15, 2011 I have already told kieran which headset to buy haha that one you linked should fit it no problem but james found his monty headset now as well so we guna give that to kieran to try. ah nice one thought youd pop up Sweet, long as he gets it sorted Quote Link to comment Share on other sites More sharing options...
