Disc Adaptor Query
mr.tattoo
got a apir of old echo disc mount forks, got a disc caliper i need on it but i need an adaptor as fitings are diferent, i need it so the bracket bolts on side of fork but facing back for caliper am i right thinking this is is to post mount? ive a 160 disc so are all brackets the same hole spacing on the forks? cheers
yeah that tarty one looks like the shape i need just wanted to check if the holes are diferent etc as i got a bracket off an old xc bike and the fork hole spacing much smaller on these echo forks.
If the Echo ones you mean are the ones I gave you, then they are indeed standard IS spacing, so if you have a post mount brake then you just need an IS to Post Mount adaptor. The mount on those forks is for a 160mm disk, so I think the smallest disk you'll be able to run with an adaptor is 180mm but that's a great size for the front anyway (Y)
EDIT: That's assuming the adaptor adds to the size, but I've never needed to go IS -> PM before so I wouldn't know.
Edited by JD™
