Rim And Brake Help
onza1
Hey
Bought a new rear wheel and it's too wide to fit the brakes on!!! :( so ordered some offset mounts but was just wondering whats the biggest size wheel a phase 1.2 can take with brakes set up perfect?
Cheers
Edited by onza1
Think mine is a 47 but not sure know it's a echo rim but don't know which one!! I will cry if I hav buy a new rim it's already cost me a fortune :(
Doubt it will be any wider than 47mm matey, you'll be fine with offset mounts but even if (very strong if) it won't fit then you can always sand your pads down a couple of mm :)
