Blake Posted November 5, 2011 Report Share Posted November 5, 2011 hello, as title says, would like to replace my 04 TPA with an M5 bolt but can't find a thread with pictures because they all seemed to have expired.. Have used search bar but all threads don't have pictures. Can someone help me out? Thanks Quote Link to comment Share on other sites More sharing options...
Mikee Posted November 5, 2011 Report Share Posted November 5, 2011 I couldn't find it either but it's dead simple. Take the lever blade off. Fully unscew the tpa (a 2p coin might help with this). lever off the red tpa wheel with a screwdriver. And screw the bolt into the bit with threads inside that sits in the lever blade. Put the lever blade back on and it's done. You can also grind a slot in the new bolt head and cut it down a tad if needed, drill a whole in the the TPA wheel and put it back together like it was before but stronger. This is that I do. Quote Link to comment Share on other sites More sharing options...
Blake Posted November 5, 2011 Author Report Share Posted November 5, 2011 Got it sorted now thanks mate! Can finally use my more comfortable lever blade now! Quote Link to comment Share on other sites More sharing options...
