How Do I Get My Rear Sprocket Off?
Laurence--Trials
As title says, how do i get my rear sprocket off, was unbuilding my wheel and realised i've got to take the sprocket off to get the drive side spokes out and the new ones in. Half the spokes arn't in there and all of them are very loose, how do i get it off?
Put the spokes back in :)
thats the only way? seriously?
Pretty much, if you have one side of the wheel laced up already you might be able to get enough tension on those spokes in order to resist the torque required to remove the sprocket. Failing that, put some of them back in the unlaced side and you should be able to remove the sprocket as normal.
edit: it should only take you 20 minutes or so to put the spokes back in, the wheel doesn't need to be trued, just tensioned a little; besides which its good practise for lacing ;)
Edited by forteh
Google Sheldon Brown for all the wheelbuilding expertise you'll ever need - it's not hard when you follow the instructions (Y)
I'm hoping I got that name right, for some reason I think I might be referring to the guy of the Big Bang Theory...
That's Sheldon Cooper ;)
So i just got alex trials boy (forum name) round to help get it off, used the same techneque as adam in his tarty video. Couldn't be bothered to tighten up the spokes... and guess what happened
Yep...
We snapped the 1300kg load chain >_<
Yeah i had a mate with a TI sprocket and he tried getting it off using the tarty video and it completely destroyed his sprocket???
Dam things...
try this way.....
wrap the chain around the sprocket as normal, but make the chain miss one tooth out (make the chain make a small triangle shape). Put the cog with chain in a vice and now when you turn the wheel the kink in the chain will not allow it to spin and not waste the clamping force of the vice. You'll probably need two people to turn the wheel, having the tyre inflated will help loads too. When working at Tartybikes this system never failed.
Bit too late now... sprocket is a square with no teeth, alex is going to rebuild the wheel then with ALL the spokes tight and in place try to undo the wheel like that, will use the tube/tyre with it too!!
mate, if you still have the hub with sprocket on, (wheel not built) I can probably cut it off with my tools for you a bit better. i have a sneaky suspicion an angle grinder isnt the best way to get it off.. lol
cant be f**ked with pissing around with chain tools ect ect
Assuming you've ever bought a chain and cut it to length to fit your bike, you'll have an off-cut big enough to do this, so the only "tool" you need is a vice. Shitload easier and cheaper than anglegrinding a sprocket off.
I really dont know how to do this anymore. wheel has been built onto the new rim so i can give it some propper tugging without worrying about the spokes snapping. However if i put the sprocket in the vice and pull it, it'll just slip round. I'll probally have to grind the f**king thing into a grip-able shape but is there any way to make it easyer, i was pulling it with the tyre/tube on.
