Greetings Posted November 2, 2011 Report Share Posted November 2, 2011 Just wondering if the Servo Wave system has turned Shimano brakes from the Deore groups into something that can be used for trials as succesfully as a properly set up Avid BB or Hope Trials? In the tech info I found that this system increases braking power by 20% but that sounds like a bit much - it's roughly the difference between using a 160mm rotor and a 203mm rotor. I'm looking at experimenting with a few disc brakes in the winter to see what's what, wondering if these are worth a shot. I mean specifically Deore group brakes, not Saint. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted November 2, 2011 Report Share Posted November 2, 2011 I've only used the servo wave XT cable lever but there are multiple settings you can choose depending on how much assistance you want, the more power gained through servo the more spongy and horrible the brake felt. That was only on a single XT front vee setup though, other setups might be better. Quote Link to comment Share on other sites More sharing options...
sstein Posted November 3, 2011 Report Share Posted November 3, 2011 never used deore but i have tried last years xt and slx and they were both superb Quote Link to comment Share on other sites More sharing options...
Ali C Posted November 3, 2011 Report Share Posted November 3, 2011 they are all usable for trials, Dominik Raab uses front and rear XT brakes on his 26" (with 160mm rotors too I think!). Quote Link to comment Share on other sites More sharing options...
SamKidney Posted November 3, 2011 Report Share Posted November 3, 2011 (edited) they are all usable for trials, Dominik Raab uses front and rear XT brakes on his 26" (with 160mm rotors too I think!). So the XT brakes are a good choice? Bite, hold? Guessing you have to leave them to bed in for a while.... Edited November 3, 2011 by Echo Lite 09 Quote Link to comment Share on other sites More sharing options...
Andeee Posted November 3, 2011 Report Share Posted November 3, 2011 Guessing you have to leave them to bed in for a while.... Like most brakes yes.. Quote Link to comment Share on other sites More sharing options...
SamKidney Posted November 3, 2011 Report Share Posted November 3, 2011 Like most brakes yes.. I meant compared to Hope Mono Trials. Mono Trials have brake pads designed with trials in mind, so they dont take long to bed in. (I know this as Ive set up jakes brake recently with new pads and they took no time at all) Compared to XT brakes that are MTB orientated with harder pads, I would expect them to take a little longer to bed in. Was asking Ali seeing as he knows what he's on about here. Quote Link to comment Share on other sites More sharing options...
Greetings Posted November 3, 2011 Author Report Share Posted November 3, 2011 Mono Trials have brake pads designed with trials in mind, so they dont take long to bed in. One has pretty much nothing to do with the other. Trials disc brakes are meant to have more locking power rather than shorter running in times. Cheers for the opinions, might give the XT a try some time soon. Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted November 3, 2011 Report Share Posted November 3, 2011 One has pretty much nothing to do with the other. Trials disc brakes are meant to have more locking power rather than shorter running in times. Cheers for the opinions, might give the XT a try some time soon. Deores seems to be even stronger than slx or xt brakes according to tests in bikeradar though. Quote Link to comment Share on other sites More sharing options...
Greetings Posted November 4, 2011 Author Report Share Posted November 4, 2011 Deores seems to be even stronger than slx or xt brakes according to tests in bikeradar though. Do you mean the M596 brake? Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted November 4, 2011 Report Share Posted November 4, 2011 nah,I mean this http://www.bikeradar.com/gear/category/components/disc-brake-systems/product/review-shimano-deore-m595-brake-caliper-11-37554/ but 596 are great too I guess Quote Link to comment Share on other sites More sharing options...
Greetings Posted November 4, 2011 Author Report Share Posted November 4, 2011 It seems that they've replaced the long non-assisted lever of the M595 with a short SW lever in the newer model. That said, the M596 can be got over here for 35 quid so it'd be stupid not to try one out. The hydraulic levers are about 15 quid, combined with an Echo TR caliper that could give some serious firepower. Deffo going to experiment with these in the winter. Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted November 4, 2011 Report Share Posted November 4, 2011 It seems that they've replaced the long non-assisted lever of the M595 with a short SW lever in the newer model. That said, the M596 can be got over here for 35 quid so it'd be stupid not to try one out. The hydraulic levers are about 15 quid, combined with an Echo TR caliper that could give some serious firepower. Deffo going to experiment with these in the winter. yeah I know they are really bargain,I was also considering one,but I decided to keep my Vees. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted November 4, 2011 Report Share Posted November 4, 2011 It seems that they've replaced the long non-assisted lever of the M595 with a short SW lever in the newer model. That said, the M596 can be got over here for 35 quid so it'd be stupid not to try one out. The hydraulic levers are about 15 quid, combined with an Echo TR caliper that could give some serious firepower. Deffo going to experiment with these in the winter. Didnt you say you've tried this before? Quote Link to comment Share on other sites More sharing options...
Greetings Posted November 4, 2011 Author Report Share Posted November 4, 2011 What exactly? I've had some experience with the Deore M525 brake, paired the lever to a Magura HS33 which worked fairly well although it was too spongy. If you mean Deore lever + Echo TR caliper than you've got the wrong person here. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted November 4, 2011 Report Share Posted November 4, 2011 Ah damn, I have the choice of either a Tech V2 front or Echo TR Disc and I'm wondering whether it'd be worth going echo in the hope that it'll work? Quote Link to comment Share on other sites More sharing options...
Revolver Posted November 4, 2011 Report Share Posted November 4, 2011 Didnt you say you've tried this before? I think Bigman was on about trying something like that. Quote Link to comment Share on other sites More sharing options...
Scott Gibbs Posted November 4, 2011 Report Share Posted November 4, 2011 Apparently some guy that rides for inspired uses the saint servo wave brakes. I've used the SLX and i really rate, them probably my fave brake i've ever used. Quote Link to comment Share on other sites More sharing options...
