Cutting Down Pads?
arw_86
i have some basically new heatsink yellows on cnc v backings. There is just way too much brake compound for me to set up my brake.
is there any way i can reduce the amount of compound to make them thinner and enabling me to fit them. They just about fitted with my old rims and started bedding in nice, but now i have new rims which are wider.
I also need a really smooth finish i guess as i run smooth rims and want a smooth feeling brake.
Also, yes i have switched the cup washers around etc, my only option is to cut them down or get new pads (currently running the onza (same as inspired) pads but they are sooooo soft and squishy i hate the feel of it through the lever.
thanks dudes
won't give a smooth shiny finish though.
Using a stanley knife (or one of those retractable long bladed knives), mark with a pen and ruler where you want to cut, ideally with the pad in a vice, but a careful hand will do. Use a bit of soapy water as lube and do long cuts along the line. It will cut though easily and give a smooth shniy finish, perfect for anodised rims.
I have the same problem with my bike, because of my BB being 122 I have to run the slaves as far inboard as I can, that means that I need to take 2-3mm off new pads in order to fit them without the cranks hitting the slaves. I used a the side of a bench grinder and it worked perfectly, doing it with a suitably fine file will also work well but will be harder to get a flat face on the pads. My yellows are now 2 years old and still got a couple of mm left in them so I wouldnt worry too much about taking that much off in the first place :)
If you are really anal you could put them in a milling machine and take the exact amount off. :shifty:
I'm sure that would just clog and deform under the cutter? Wouldn't it be way too soft?
Should be fine fly cutting it though, or if you had a very sharp raked 2 flute cutter.
