trialsnoobie Posted November 1, 2011 Report Share Posted November 1, 2011 hey ive got a 118mm bb and wondered if i could get any modern cranks with a freewheel and any bashring at all to fit? Quote Link to comment Share on other sites More sharing options...
Mark W Posted November 1, 2011 Report Share Posted November 1, 2011 That sort of depends on which frame, bashring, cranks and freewheel you're using. I think I got a BB under 118mm (think it was a 113?) to work on my Lynx using a pair of Try-All cranks, Trialtech ti halfring and an SL freewheel, but that was fairly setup specific. Quote Link to comment Share on other sites More sharing options...
trialsnoobie Posted November 1, 2011 Author Report Share Posted November 1, 2011 (edited) That sort of depends on which frame, bashring, cranks and freewheel you're using. I think I got a BB under 118mm (think it was a 113?) to work on my Lynx using a pair of Try-All cranks, Trialtech ti halfring and an SL freewheel, but that was fairly setup specific. ideally this setup http://www.tartybikes.co.uk/cranks_pair/echo_tr/c514p11196.html 170mm http://www.tartybikes.co.uk/bash_rings/trialtech_alloy_twin_bashring/c1p10420.html and an echo sl freewheel i've got a m.a.d the blue one if this helps, thanks Edited November 1, 2011 by trialsnoobie Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted November 1, 2011 Report Share Posted November 1, 2011 I had a 118mm bb on my hydrox with echo SL freewheel and tryall cranks, it worked. Quote Link to comment Share on other sites More sharing options...
beedlo Posted November 2, 2011 Report Share Posted November 2, 2011 I had a 118mm bb on my hydrox with echo SL freewheel and tryall cranks, it worked. I also had a Hydroxx mod but with a 118mm bb with Try-All cranks/bash ring/Tensile FW, it cleared fine. One other thing I would also consider would be crank to frame clearance. My Rockman would definitely not work with a 118mm bb for that reason - it almost doesn't with a 123mm. Quote Link to comment Share on other sites More sharing options...
